Home > Technical > RE: Heater problems
Nav01
RE: Heater problems
Hi all
I seem to have a problem with the heater in my RRSport, when first driven the heater operates at extremely hot temperature regardless off setting. if you stop say for shopping and drive again then the heater will only give off cold air. Just had the RRSport serviced explained to the adviser as to what was going on, he informed me that they would look for codes via diagnostics at the point of picking up the Sport the adviser told me that they found no fault via diagnostics, this weekend now it only giving off cold heat. Any ideas?
Regards
Post #446048 Mon Dec 22 2014 12:27am
KiwiCool
New Zealand 2006 Range Rover Sport SDV6 HSE Buckingham Blue
Question ? this weekend now it only giving off cold heat. What is cold heat please ? SDV6 (14.5) Corris Grey NZ Spec + door mouldings, mud flaps and tow bar
Also Audi A1 Sport + - (wife's rocket) and 1985 BMW 628 CSI
Post #446050 Mon Dec 22 2014 2:44am
Camelrock
Check coolant level, might have an air lock in the system 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #446061 Mon Dec 22 2014 10:26am
myfirstrrs
I have the same problem, the result being that it often blows hot when I want cold and visa versa. I took it to the dealers that said that there was a software update to fix this. It didn't fix it so I need to go back to them again, not going to be this year though due to Santa coming.
Post #446063 Mon Dec 22 2014 10:39am
Bodsy
Site Sponsor
EDIT - was replying to the wrong thread! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #446065 Mon Dec 22 2014 10:52am
Bodsy
Site Sponsor
EDIT - Was replying to the wrong thread! Bodsys Brake Bible
See it HERE
Post #446066 Mon Dec 22 2014 10:53am
Nav01
@ KiwiCool sorry meant it only blows cold air now.
@Camelrock thanks mate will do
@myfirstrrs yes mate will go back to the dealer, let me know how you get on.
Post #446096 Mon Dec 22 2014 3:19pm
Nav01
@Camelrock surely they should have checked the coolant level when they carried out the service.
Post #446098 Mon Dec 22 2014 3:22pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Any update, how'd you get on with the heater problem? Mine seems to have developed the same fault. Evil or Very Mad
Post #488564 Mon Feb 22 2016 9:16pm
MOB4LIFE
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Java Black
Check your heater controller could be faulty - i had the same problem years ago. RRS 3.0 AUTOBIOGRAPHY DYNAMIC 2016
RRS 3.0 AUTOBIOGRAPHY 2012 GONE
RRS 2.7 2008 GONE
BMW X5 M 2005 GONE
BMW M3 2003 GONE
Post #496615 Fri May 20 2016 2:48pm
