![]() | Home > Wheels & Tyres > Do you struggle to line your holes up when changing wheels? |
Miggit Member Since: 18 Dec 2014 Location: Milton Keynes Posts: 11 ![]() ![]() |
Italy is a mine field of it's own, I've been talking with a very nice chap in Italy on ffrr and he brought a CD changer for his ffrr on fleabay, it was sent R/M recorded with tracking number. It left the UK ok, but managed to loose it's self between the shipping company and the Italian post office |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Italy have always been pretty ropey for mail deliveries. Spain is not too far behind. Its quite hit and miss.
Thanks, it's good to know which carriers suit which countries!
Lew White Member Since: 08 Dec 2009 Location: Adelaide Posts: 40 ![]() ![]() ![]() |
Hi.
Hi Loneranger.
andynpz Member Since: 20 Sep 2014 Location: Cotswolds Posts: 49 ![]() ![]() ![]() |
These might not be a million miles away from the right thread size
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
That Ebay listing is for a fitting with bolts. Landrovers use Nuts onto Studs itisme |
I use an old box spanner on my D2. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
harrygh60 is correct, Range Rover Sport, Range Rover and Discovery 3 / 4, all have wheel studs on the car and wheel nuts to hold the wheel on, not the cheaper, and weaker, wheel bolts that you find on some cars. To make a wheel guide for a car with wheel bolts, is a simple case of getting a long bolt with the correct thread and cutting off the head!
I should add the Box spanner I used just fit over the wheel studs perfectly |
The box spanner has to be thin enough to go through the stud hole in the wheel. There is not a lot of clearance betwen the stud and the wheel hole itisme |
simmogra Member Since: 25 Jan 2013 Location: Gold Coast Posts: 2 ![]() ![]() ![]() |
Hello Everyone
Just to let people know that Santa's little helpers have been busy and I now have stock again |
