Home > Wheels & Tyres > Do you struggle to line your holes up when changing wheels? |
Miggit Member Since: 18 Dec 2014 Location: Milton Keynes Posts: 11 |
Italy is a mine field of it's own, I've been talking with a very nice chap in Italy on ffrr and he brought a CD changer for his ffrr on fleabay, it was sent R/M recorded with tracking number. It left the UK ok, but managed to loose it's self between the shipping company and the Italian post office He said that this quite often happens and UPS, Fed X, or DHL are much better options, as there is only one party involved rather than 3. Yesterday I couldn't spell Engineer, today I are one!
Tue Dec 23 2014 11:47pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
Italy have always been pretty ropey for mail deliveries. Spain is not too far behind. Its quite hit and miss.
Wed Dec 24 2014 12:06am |
Thanks, it's good to know which carriers suit which countries!
Wed Dec 24 2014 12:20am |
Lew White Member Since: 08 Dec 2009 Location: Adelaide Posts: 40 |
Hi.
Wed Dec 24 2014 2:25am |
Hi Loneranger.
Wed Dec 24 2014 2:37am |
andynpz Member Since: 20 Sep 2014 Location: Cotswolds Posts: 49 |
These might not be a million miles away from the right thread size
Sat Jan 03 2015 12:59am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
That Ebay listing is for a fitting with bolts. Landrovers use Nuts onto Studs itisme |
Sat Jan 03 2015 8:28am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I use an old box spanner on my D2. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Jan 03 2015 9:35am |
harrygh60 is correct, Range Rover Sport, Range Rover and Discovery 3 / 4, all have wheel studs on the car and wheel nuts to hold the wheel on, not the cheaper, and weaker, wheel bolts that you find on some cars. To make a wheel guide for a car with wheel bolts, is a simple case of getting a long bolt with the correct thread and cutting off the head!
Sat Jan 03 2015 11:14am |
I should add the Box spanner I used just fit over the wheel studs perfectly (basically similar to using a bit of old pipe/tube). However I doubt it will fit the Sport as the wheel nuts are smaller In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Jan 03 2015 1:36pm |
Guide-o-Matic's will fit Yesterday I couldn't spell Engineer, today I are one!
Sat Jan 03 2015 3:01pm |
The box spanner has to be thin enough to go through the stud hole in the wheel. There is not a lot of clearance betwen the stud and the wheel hole itisme |
Sat Jan 03 2015 3:54pm |
simmogra Member Since: 25 Jan 2013 Location: Gold Coast Posts: 2 |
Hello Everyone
Tue Jan 13 2015 2:04pm |
Just to let people know that Santa's little helpers have been busy and I now have stock again Yesterday I couldn't spell Engineer, today I are one!
Sat Jan 24 2015 12:22pm |
