Home > Technical > Automatic wipers now don't work
Andyjay123
For some reason the auto function has stopped
I have to manually put them on
Does anyone know how I can get the auto function back please 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #445633 Wed Dec 17 2014 1:56pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Auto Wipers
If you read the manual it tells you to move the wiper stalk up one notch. Nothing will happen until the windscreen gets wet.As i have said before do not leave it in auto mode overnight in cold and frosty weather. As soon as you turn ignition on, the wipers will try to operate.If they are frozen to windscreen they will get torn or the motor could burn out Big Cry itisme
Post #445648 Wed Dec 17 2014 3:58pm
Andyjay123
I kno that but thanks.
When i turn it up one notch it comes on without the windrscreen being wet!!!
andy 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #445649 Wed Dec 17 2014 4:05pm
SRE
Spain
You don't turn it up one notch, you move the lever up a tad Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #445665 Wed Dec 17 2014 7:02pm
DaveB
It seems odd it would just suddenly fail but I do know from a recent experience that when the sensor does fail the wipers revert to a normal delay function on the first click up. The sensitivity dial then simply adjusts the delay. As the OP says, you then have to turn them off manually as the delay function will continue to work whether the screen is wet or not.
All I can suggest from my recent experience is that you'll need a new sensor unless something else has been done to interfere with any wiring? It's easy enough to replace.
HTH.
Post #445716 Thu Dec 18 2014 11:55am
