Home > Technical > Heating problem pls help
Irish John
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Forgive me pls if this question has been asked I'm new lol
I've recently bought a RRS tdv6 2007 hse I've just discovered that the heater on the drivers side blows cold
Passenger side is working ok any tips advise ideas help would be greatly apriciated
Tia. John
Post #444506 Sat Dec 06 2014 3:08pm
Camelrock
Sounds like it could be an issue with the blend motors, find an indi who can read the fault codes and reset. On the D3's you can do a self test on the climate control I don't know if you can do the same on RRS though it's the same system so carn't see why not. Somebody on here might tell you how to do it as I carn't remember.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #444517 Sat Dec 06 2014 6:09pm
Irish John
Thank you for the reply and the info camelrock
Post #444538 Sat Dec 06 2014 10:39pm
ian-r
Here is self test / reset:
Here the self test procedure:-
"With ignition off press and hold the ECON & RECIRC buttons whilst turning ignition on (no need to start car).
The control module will then compare the current HEVAC actuator motor positions with the values stored in the module and will indicate an error by flashing the ECON LED.
If there are no errors, the LED will go out and the system will function normally.
To confirm that there are no errors, turn the ignition switch to the OFF position, then back to the ON position.
Observe the operation of the programmed defrost LED.
If there are errors present, the programmed defrost LED will flash and the system will attempt to calibrate itself."
If that doesnt work odds on it will be a blend motor or blocked heater matrix.
Post #444583 Sun Dec 07 2014 7:42pm
Irish John
Hi Ian-r
Thank you for the information I've tried this now cut still got the same problem
So I will get it booked in to be looked at the garage
But thanks for your help
Cheers john
Post #444593 Sun Dec 07 2014 8:12pm
Jukka69
Finland 2005 Range Rover Sport Supercharged Vesuvius Orange
Just made this self test
Hi
I just made test based on your info. Econ flashed but programmed led doesn't so I think I have to go to workshop...
Br jukka from Finland
Post #484386 Sat Jan 09 2016 8:28pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
How does this reset work then, if you have a 2010 Sport without the economy button?
Cheers Dean
Post #646480 Fri Jan 24 2025 5:40pm
