Home > Technical > Heating problem pls help |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Sounds like it could be an issue with the blend motors, find an indi who can read the fault codes and reset. On the D3's you can do a self test on the climate control I don't know if you can do the same on RRS though it's the same system so carn't see why not. Somebody on here might tell you how to do it as I carn't remember.. 2008 G4 RRSport TDV8 current
Sat Dec 06 2014 5:09pm |
Irish John Member Since: 06 Dec 2014 Location: Stone staffs Posts: 4 |
Thank you for the reply and the info camelrock |
Sat Dec 06 2014 9:39pm |
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 |
Here is self test / reset:
Sun Dec 07 2014 6:42pm |
Hi Ian-r
Sun Dec 07 2014 7:12pm |
Jukka69 Member Since: 09 Jan 2016 Location: Sipoo Posts: 3 |
Hi I just made test based on your info. Econ flashed but programmed led doesn't so I think I have to go to workshop... Br jukka from Finland |
Sat Jan 09 2016 7:28pm |
RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 51 |
How does this reset work then, if you have a 2010 Sport without the economy button?
Fri Jan 24 2025 4:40pm |
