Home > General > Vehicle Inspection Completed - Advice Required
Page 1 of 3 123>
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Just got Betsy back from Steve Parks, and a few things have come to light. The car was purchased 2 weeks ago today from a dealer (Extreme Sports & Performance). I could do with a little advice on what I am actually covered for etc etc. Also, which of the issues (if not covered by warranty) could a competent mechanic complete?
Here is the original advert on eBay:
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...7675.l2557
The car is under warranty from "Customer Protect" under Silver Plus:
http://www.autoprotect.co.uk/customer-protect
The details of the inspection are:
* Air Flow Meter Zero Reading
* RH EGR Valve stuck at 5%
* RH Front Lower Suspension Arm Ball joint worn, some wear to LH ball joint
* Locking wheel nuts splitting
* Oil Level low
* Suspect oil leak from LH Rear cam oil seal
* Transfer box oil leak
* Rear pads worn 90%
* Rear discs worn
* Some corrosion to ARC Pipes - Advise to clean up and grease with copper grease
With the listed oil leaks, there has been no oil on my driveway.
As always, advice and guidance really appreciated! Thumbs Up
 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #442655 Sat Nov 15 2014 1:40pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
The link doesn't work mate. Personally, I would e mail that list to the dealer and very politely ask them if they are happy to have sold a car like that and leave the ball in their court for a while.
What year is it?
Post #442657 Sat Nov 15 2014 2:40pm
SRE
Spain
Talk to seller, also talk to Warranty Company
You need to get these sorted
* RH EGR Valve stuck at 5% (This can be blanked)
* Air Flow Meter Zero Reading (Remap Specialist did not find this!!!!!)
* RH Front Lower Suspension Arm Ball joint worn, some wear to LH ball joint Has the Car had a new MOT, if so this should have been picked up.
Simple fix
* Rear discs worn (depends how warn)
* Locking wheel nuts splitting (New wheel nuts)
* Oil Level low In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #442659 Sat Nov 15 2014 3:03pm
darrenmcneill
What year is it?
Ive emailed the dealer and cc'd in Steve Parks. Will wait to see what he comes back with. The EGR is being blanked on Tuesday anyway. I don't really want to do anything until I know if/what I'm covered for.
What concerns me is Tha the car has apparently "just" been serviced (but the oil needed topping up, and it has just got a new MOT..... 2006 HSE for Sale - £7,499 (Manchester)
Post #442660 Sat Nov 15 2014 3:17pm
KEV1N
United Kingdom 2008 Range Rover Sport TDV8 HSE Rimini Red
LAND ROVER RANGE ROVER 'HSE A' 2.7 TD V6 AUTO IN EXCELLENT ALL ROUND CONDITION!!! THIS IS A GREAT FAULT FREE EXAMPLE THAT IS 100% READY TO GO AND NEEDS NO MONEY SPENDING ON IT, NO REPAIRS ARE NEEDED.
Not exactly what it says on the tin is it?
I'd have a word with the dealer...
Post #442661 Sat Nov 15 2014 3:21pm
I would have emailed the garage with the list of faults, followed it up with a phone call if they hadn't got back intouch within an hour of sending the email, ask to speak to the dealer principle, and ask them what they are going to do to put the vehicle right and go from there. If they put the onus on the warranty company and tell you to contact them, contact them with the list of faults that you have received from your inspection, and explain you were sold the vehicle like this and not as described in the advert. I'm sure the warranty company will be straight on the phone to the garage you bought your car off. Option 2, Ask for a full refund and shop elsewhere. Option 2 would be my one and only choice.
Good luck, keep us updated.
Post #442663 Sat Nov 15 2014 3:51pm
darrenmcneill
Thanks for the advice.
Found this an interesting read:
http://www.theaa.com/motoring_advice/car-b...ights.html
I have 30 days to get my money back, I'm on day 13.
Steve Parks said not to panic and the car was in good condition. Its just these bits. Will wait to see what the dealer comes back with.
I have kept every email between us, and also a physical print out of both adverts (eBay and Website). I'm sure things will get sorted! Whistle 2006 HSE for Sale - £7,499 (Manchester)
Post #442664 Sat Nov 15 2014 4:03pm
drdelrrs
Your beef is with the dealer - don't be fobbed off by what's or isn't covered in the 3rd Party warranty. These faults obviously existed prior to sale so under Consumer Law the dealer must correct them - it does not matter to you whether or not there is a contribution from the warranty firm. The warranty only covers faults arising after you take responsibility and ownership of a Fit for Purpose vehicle.
Keep the selling firm on the hook - if they won't agree to rectify the faults get a quote from a LR Dealer and send to your seller saying they have 7 days to agree other wise you will action the repairs and claim the costs plus your reasonable out-of-pocket expenses via the Small Claims Court.
Don't mess about.
Post #442677 Sat Nov 15 2014 8:05pm
darrenmcneill
Thanks for the advise.
Will persue the matter. Ive emailed the seller (no response yet). Everything is documented, and I've read up on my legal rights etc. I'm keeping the car, as apart from these bits its sound. Just glad I invested my money in an inspection for my piece of mind!
If I need to go to small claims then I will do.
I'm sure everything will be resolved amicably. 2006 HSE for Sale - £7,499 (Manchester)
Post #442681 Sat Nov 15 2014 9:39pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
just to say , is it the garage you took it to trying to get work that does not need doing any way only a thought or it is a 10 year old car with 126k on it will need work it aint brand new and come on it is a landrover
Post #442686 Sat Nov 15 2014 10:21pm
darrenmcneill
Yeah, I get the age of the car and the mileage, but the advert clearly states that the car is fault free. It had just had an MOT, so a few of the issues would have been noticed then.
I was also told it had just been serviced, but the car needed oil topping up as it was low....? Surely in 2 weeks it wouldn't be that low?? 2006 HSE for Sale - £7,499 (Manchester)
Post #442695 Sun Nov 16 2014 6:04am
Bladeboy
I think my main concern would be, if you take the best case scenario and it was serviced recently as they say, then where has that oil gone? Was it s LR service or was it the dealer who sold it?
Post #442696 Sun Nov 16 2014 6:24am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Every single year my wife's Audi goes to a main dealer for a service and every year within a fortnight I have to add more oil,I just think their bone idle when it comes to checking the level properly Rolling Eyes
Post #442698 Sun Nov 16 2014 8:00am
darrenmcneill
Upon investigation, the last service was completed by the sellers garage. How could I validate?
Ive also emailed the Land Rover deals who the car was purchased from, along with all of its previous services, to try and establish what work they have completed on the car etc. Not sure how helpful they will be yet. 2006 HSE for Sale - £7,499 (Manchester)
Post #442701 Sun Nov 16 2014 8:45am
darrenmcneill
Response from the seller:
It most definitely has been serviced, it has full history by JV Likes (LR main dealer not an Indy). They only use LR products, my mechanic uses Fram filters, I can get the part number of the oil / air filter used that you will find fitted in the engine.
The oil used was Synta full synthetic 5/30 as supplied by TPS, you'd be very welcome to not only ID the filters but also the oil.
I hope this doesn't come across as arrogant, if I promise it's been serviced I can promise it's been serviced Smile
The warranty is a mechanical & electrical one and doesn't cover wear & tear, no aftermarket warranty would.
The AFM would be covered but not wear / tear in joints etc especially on an 8 year old 4x4 with 126k under her belt. The transfer box was definitely not leaking on the point of sale as I used to park it on my new drive so I'd have noticed..........or my wife certainly would!
However, If it has started to leak then I'd be more than happy to get this repaired for you and whilst it's here if the brakes are deemed low ( this surprised me somewhat as I have Brembo pads etc here so don't mind changing them) these will also be replaced for you
Think that's a positive start, just emailed back to clarify each issue in detail. 2006 HSE for Sale - £7,499 (Manchester)
Post #442709 Sun Nov 16 2014 10:32am
Page 1 of 3 123>
