Home > General > Vehicle Inspection Completed - Advice Required
Page 2 of 3 <123>
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Dealer is fixing everything!! Result! Thumbs Up
Got to drive 4hrs to Wales though as it will be fixed there, but to be honest I don't mind, 1 day and half a tank of juice to fix £2000 of issues!
Day out in Cardiff ny the looks of it! 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #442714 Sun Nov 16 2014 11:46am
SVR575
I should Censored think so! Good out come though. SVR 2018 in Santorini Black.
Post #442717 Sun Nov 16 2014 12:28pm
SRE
Spain
Good result, get them to give you a loan car for the day. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #442718 Sun Nov 16 2014 12:34pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
That is a good result mate.
Post #442735 Sun Nov 16 2014 6:04pm
362bkr
Well they did the right thing Thumbs Up
Post #442755 Sun Nov 16 2014 7:49pm
darrenmcneill
Ive just been under the car..... And then I started thinking..... And now I feel like a bit of a Censored
Last week I had the Terraclean done. To do this it involved the fuel line, and before hooking up to it, and after hooking up to it, quite a bit of diesel was spilt. Now looking at the base of the car, this does link in with the terraclean. The seller said he hadnt had any leaks on his drive, and I hadnt up until this week....
Rubbed my finger on the markings in numerous places, and it does smell like diesel I think.... And would the volume be too much for:
* Suspect oil leak from LH Rear cam oil seal
* Transfer box oil leak?
The car is going into my local garage for the EGR valves to be blanked Tuesday, is there an easy way for them to check, or is it a big job just to look at the Cam seal and Transfer Box?
If it is just diesel, I feel like an arse, but at the same time it will save the dealer some money, and he has seemed to be a genuine nice guy.... It does look more Diesely than oiley... but surely the Land Rover Garage would have been able to tell the difference?
Post #442757 Sun Nov 16 2014 8:13pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Not an expert but it does look like diesel and not oil.
I would still let the dealer investigate and see what he comes up with. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #442763 Sun Nov 16 2014 8:32pm
darrenmcneill
Its a 4.5 hour drive to the dealers, so tbh id rather find out before hand!! 9hrs driving to be told its diesel isnt my idea of a fun day!! Big Cry 2006 HSE for Sale - £7,499 (Manchester)
Post #442765 Sun Nov 16 2014 8:48pm
darrenmcneill
Been thinking....
Will these diesel marks go over time? Just that if there ever was an oil leak in the future id never know......? 2006 HSE for Sale - £7,499 (Manchester)
Post #442878 Tue Nov 18 2014 12:08am
drdelrrs
Take you 5 mins to tell. Just get some on your fingers.
- You should be able to feel the difference between your fingers - diesel is a lot thinner than engine oil and leaking engine oil will make your fingers very black ! - if its diesel your fingers will stink !!
Post #442922 Tue Nov 18 2014 3:18pm
darrenmcneill
Well.... Interesting day..... Very Interesting.....
Car has been to my local garage, who I have been using for years. They have just fitted my EGR valves, and also copper greased a few pipes that had been recommended to me.
Anyway.... while I was there I asked them just to have a look at the suspected oil leaks, as I have mentioned about the diesel. They pulled off the covers and had a good look... There is a tiny leak from the transmission box. And by tiny, they said they really struggled to find it, and said it wasnt anything to be slightly worried about. They also made a comment (which I wont repeat) about the rear brakes and discs being absolutely fine.... In fact the comment involved a certain person who "must own a yacht"......
I then rang the guy who I bought the car off, and had a good 30 minute conversation. He also stated that he didnt think there had been any of those issues, as the car had been serviced by Likes Land Rover, and his MOT guy was a very detailed character who picked up on everything! His own lads also did a check, and didnt find anything....
Now, Im not one to point fingers.... but something here does sound a little bit suspect?? But something here does not add up, and I now know of a garage that I will not use again.
My seller is sending me the money to have the MAF replaced..... 2006 HSE for Sale - £7,499 (Manchester)
Post #442927 Tue Nov 18 2014 3:46pm
darrenmcneill
Just having a puncture sorted....
Rear discs:
Does that look ok? Ive no idea! Lol 2006 HSE for Sale - £7,499 (Manchester)
Post #442931 Tue Nov 18 2014 4:41pm
Paddi
Oh dear. Should look like this:
Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #442937 Tue Nov 18 2014 5:16pm
darrenmcneill
Hmmmm....
Maybe not the red!!! But the disc's are fine? 2006 HSE for Sale - £7,499 (Manchester)
Post #442940 Tue Nov 18 2014 5:32pm
Paddi
To be honest the painted bells are barely visible when the wheel is on and look a lot better than the usual rusty crusty mess that ensues when an unpainted disc is fitted.
Your disc looks to have a bit of a lip at the outer edge and some scoring on the braking surface. Can't see the depth of pad left but if your garage advised they are OK then just keep an eye on the wear until the pads are thin and next time replace pads and discs. It is a false economy not to have the handbrake shoes and mechanism stripped, cleaned, lubricated and adjusted at the same time. 2008 MY Java Black TDV8 HSE
Post #443041 Wed Nov 19 2014 11:15am
Page 2 of 3 <123>
