Home > Technical > Suspension Fault "normal height only"
pigd0g
Hi,
I've got this common issue, from research it seems that it could be the air suspension compressor. But, before I buy this part and have it fitted I wondered if anyone can confirm it is that part.
When I start the car the compressor makes a bit of a noise until the dashboard light comes on and cuts it out.
I have had the fault codes read and there's a number of faults which all seem related:
C1A20 Pressure increases too slow when filling reservoir
U1A13 Lost communication with terrain control module
C1A02 Rotary encoder stuck in intermediate position
U0421 Invalid data received from ride level control module
Could anyone advise me on a next step - does this sound like the air suspension compressor?
Thanks for any help in advance
Post #441933 Sat Nov 08 2014 10:59am
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
mine was the same , got a full rebuild kit off ebay , fitted and now good as gold , pump can be a problem to remove as they get very corroded
Post #441958 Sat Nov 08 2014 5:38pm
Stuart
Mine was doing this each day, but showing no other symptoms, the garage confirmed a compressor was needed.
It was fitted a few months ago and good as gold for a bit, but it still comes up now and again. It seems to be one of those faults that throws up with any one of a number of issues. I know from reading here that other electrical gremlins that plague these cars can cause this too.
Next time mine is in for a service, they will plug it in and I am sure it will swallow another grand to turn all the intermittent lights out. Nature of the beast.
Post #441984 Sun Nov 09 2014 1:24am
