![]() | Home > Technical > Suspension Fault "normal height only" |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
mine was the same , got a full rebuild kit off ebay , fitted and now good as gold , pump can be a problem to remove as they get very corroded |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine was doing this each day, but showing no other symptoms, the garage confirmed a compressor was needed.
