![]() | Home > Maintenance & Modifications > Confused about which LED bulbs |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 ![]() ![]() ![]() |
rear passenger light conversion tomorrow - what is that? |
JamesRoberts Member Since: 02 Oct 2014 Location: Hampshire Posts: 116 ![]() ![]() ![]() |
Did my interior and reverse bulbs. Wow I can now see after 1630! |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
When you open the rear doors, only the door puddle lights come on, the interior lights above the door do not, nobody can see anything in the dark and its very annoying. This fixes that issue. Its well documented on this forum how you do it. Landrover messed up over this, yet they wont ever admit it 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ![]() |
Link? Search failed me or most likely I failed it |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Did you complete the upgrade? 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
Im going to maplins tomorrow for the diodes, should be done by teatime 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
No Diodes in stock |
Will this help |
it certainly does, and to think the Diode is only 10p, and Maplins are charging 58p, robbers.
Just done this mod, not as easy as others as the reading lamp supply did not have enough free movement in them, i had to strip the rear trim off and pull the headlining down for access, managed to gain a extra 6" on one supply but the other side would not budge, despite a lot of tugging. I soldered the new feed onto the bulb holder in a vice, also did the same for the diode and then fed the wires through as a complete Unitrather than trying to solder in the car, i also did not change the bulbs to leds untill it was all working 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
All the fitting come out/apart with a small screwdriver, your handbook will show you a picture of the correct way, I have not done my side repeaters, never thought of them to be honest, though I did replace the daytime running lights in the head light unit 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46 ![]() ![]() ![]() |
Thanks a lot, the LED's should arrive by next week hopefully then I am going to give it a go. |
LED's arrived today and wow what a difference. Took less than 20mins to swap out all the interior bulbs. Mighty chuffed and what a cheap upgrade for the RRS. |
Now you're next mod is the rear passenger reading lights |
