Home > Maintenance & Modifications > Confused about which LED bulbs
Page 2 of 3 <123>
TheDB
rear passenger light conversion tomorrow - what is that?
Post #442640 Sat Nov 15 2014 11:47am
JamesRoberts
United Kingdom 2005 Range Rover Sport TDV6 SE Cairns Blue
Did my interior and reverse bulbs. Wow I can now see after 1630!
Post #442650 Sat Nov 15 2014 12:26pm
shakeapaw
When you open the rear doors, only the door puddle lights come on, the interior lights above the door do not, nobody can see anything in the dark and its very annoying. This fixes that issue. Its well documented on this forum how you do it. Landrover messed up over this, yet they wont ever admit it 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #442669 Sat Nov 15 2014 5:47pm
TheDB
Link? Search failed me or most likely I failed it Smile
Post #442771 Sun Nov 16 2014 9:29pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Did you complete the upgrade? 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #442772 Sun Nov 16 2014 9:38pm
shakeapaw
Im going to maplins tomorrow for the diodes, should be done by teatime 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #442780 Sun Nov 16 2014 11:40pm
shakeapaw
No Diodes in stock Confused Confused They have ordered some, should be here in 5 days, in the meantime here is the link to the conversion.
http://www.rrsport.co.uk/forum/topic20566.html
The Diodes are not in a apacket, they are single stock items and are kepted in the back room so dont waste your time looking for them, go to the desk at the rear of the shop, they are 58p each. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #443102 Thu Nov 20 2014 7:19am
SRE
Spain
Will this help Thumbs Up
http://www3.telus.net/alansweb/RRS/reardoorlights/ In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #443104 Thu Nov 20 2014 8:06am
shakeapaw
it certainly does, and to think the Diode is only 10p, and Maplins are charging 58p, robbers.
This way goes down the side piller and involves trim removal, never a good idea, the way I posted you go in through the headlining and pick up the boot courtesy light 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #443120 Thu Nov 20 2014 9:31am
shakeapaw
Just done this mod, not as easy as others as the reading lamp supply did not have enough free movement in them, i had to strip the rear trim off and pull the headlining down for access, managed to gain a extra 6" on one supply but the other side would not budge, despite a lot of tugging. I soldered the new feed onto the bulb holder in a vice, also did the same for the diode and then fed the wires through as a complete Unitrather than trying to solder in the car, i also did not change the bulbs to leds untill it was all working 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #443950 Sat Nov 29 2014 11:20am
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
I just order some LED's but can someone tell me how to unclip the interior light fittings? Is it easy like just a small screwdriver easy? Also how do u get into the central lighting above the dash?
Oh and can u use these same led's for the side repeaters? Not sure whether to get smoked or clear yet so haven't ordered those yet.
Thanks fellas
Tech
Post #446850 Tue Dec 30 2014 11:49pm
shakeapaw
All the fitting come out/apart with a small screwdriver, your handbook will show you a picture of the correct way, I have not done my side repeaters, never thought of them to be honest, though I did replace the daytime running lights in the head light unit 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #446882 Wed Dec 31 2014 1:01pm
Techstyles
Thanks a lot, the LED's should arrive by next week hopefully then I am going to give it a go.
Post #447108 Fri Jan 02 2015 8:53am
Techstyles
LED's arrived today and wow what a difference. Took less than 20mins to swap out all the interior bulbs. Mighty chuffed and what a cheap upgrade for the RRS. Smile
Post #447591 Tue Jan 06 2015 7:56pm
shakeapaw
Now you're next mod is the rear passenger reading lights Smile 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #447618 Tue Jan 06 2015 10:13pm
Page 2 of 3 <123>
