![]() | Home > Faults & Fixes > another suspension fault question |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
Sounds like the compressor is dying. 2012 SDV6 - it's missing a couple of cylinders
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
Now it is just sitting in access mode and won't rise and a red flashing light above the front drivers side front wheel in the 4x4 screen |
The flashing light shows either a faulty sensor or that the wheel on its bump stop.
thanks for your help RRSTDV8 would you recommend a new compressor or a repair kit mate |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
mark.b, this is what happened to my car. A new compressor sorted the problem immediately |
I'd go with a new unit. You can repair them but I've no idea how difficult it is or how long it would take. 2012 SDV6 - it's missing a couple of cylinders
Just ordered a AMK compressor unit and will replace it on saturday does anyone know if i have to update or reset the ECU once i have fitted it |
All fitted and followed the AMK compressor fitment in How to |
