Home > Faults & Fixes > another suspension fault question
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
Last night i left the car in fully raised mode ,today i drove it and the amber suspension light came on with warning NORMAL suspension only turned of and back on, lowered the car to access mode and then back to normal ride hight which only lifted the rear and a dash warning SUSPENSION WILL RISE WHEN SYSTEM COOLED DOWN and no amber warning light just got home and lowered it to access hight
Any ideas please
Post #440757 Tue Oct 28 2014 6:16pm
Sounds like the compressor is dying. 2012 SDV6 - it's missing a couple of cylinders
Post #440768 Tue Oct 28 2014 7:33pm
mark.b
Now it is just sitting in access mode and won't rise and a red flashing light above the front drivers side front wheel in the 4x4 screen Big Cry
Post #440791 Tue Oct 28 2014 9:15pm
The flashing light shows either a faulty sensor or that the wheel on its bump stop.
You need to get the fault codes read to see what the issue is. It could be something as simple as a corrupted ride height calibration (cross articulation error) - this can, in extremis, lead to the vehicle sitting on its bump stops. A single faulty ride height sensor shouldn't lead to a loss of the system just to reduced functionality.
I still think it's the compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #440805 Tue Oct 28 2014 10:43pm
mark.b
thanks for your help RRSTDV8 would you recommend a new compressor or a repair kit mate
Post #440806 Tue Oct 28 2014 10:46pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
mark.b, this is what happened to my car. A new compressor sorted the problem immediately Thumbs Up Carl
Post #440811 Tue Oct 28 2014 11:53pm
V8SC
Post #440810 Tue Oct 28 2014 11:53pm
I'd go with a new unit. You can repair them but I've no idea how difficult it is or how long it would take. 2012 SDV6 - it's missing a couple of cylinders
Post #440826 Wed Oct 29 2014 9:01am
mark.b
Just ordered a AMK compressor unit and will replace it on saturday does anyone know if i have to update or reset the ECU once i have fitted it
Post #440892 Wed Oct 29 2014 10:24pm
mark.b
All fitted and followed the AMK compressor fitment in How to Thumbs Up all i need to do now is get the software update
Post #441133 Sat Nov 01 2014 3:33pm
