Home > Technical > Heated front screen
Wayneclarke
Heated front screen
Hi guys, got in the car this morning switched on the heated front screen and about quarter of it didn't work on the drivers side the rest of the window de-misted fine. Any ideas ??
Post #438396 Fri Oct 03 2014 2:33am
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
More than likely the heating element is damaged in the screen I'm afraid.
Post #438399 Fri Oct 03 2014 5:58am
Wayneclarke
So a new screen is needed? It does have a stone chip in the middle of the screen perhaps I could get it changed
Post #438401 Fri Oct 03 2014 6:07am
rich_sargie
It's got power to it because it's working in part, but there is no way to repair it if the heating element is damaged in places. If you have windscreen cover on your insurance, it could be replaced if the screen was damaged by a bird strike or someone to that effect. Although it is unlikely to get replaced for a just chip........
Post #438404 Fri Oct 03 2014 6:22am
Wayneclarke
Ok thanks for the advice
Post #438406 Fri Oct 03 2014 6:30am
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
my screen is like that except the good bit is the drivers side, the rear screen doesn't work at all Big Cry
if anyone has any pointers on the rear it would be great to hear Thumbs Up
Post #438455 Fri Oct 03 2014 6:09pm
Signori
Hi all,
Instead of starting another thread about heated front screens i'll just ask here.
Going off my pictures do you think there's something up with my screen? It clears some bits really quickly but not the others, they're kinda in strips
Post #574516 Mon Feb 04 2019 4:32pm
Wayneclarke
That’s how mine started on one side now more or less the whole drivers side does not work, but the passenger side clears lovely
Post #574523 Mon Feb 04 2019 5:28pm
If some strips take longer, then they take longer.
If they never clear, then its broken
Post #574527 Mon Feb 04 2019 5:55pm
syl
I've had heated screens for 25 years or more (originally on Fords). They all do that after a while and the only resolution is a new screen. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #574533 Mon Feb 04 2019 6:40pm
The old ford ones lasted longer though Whistle
Post #574540 Mon Feb 04 2019 8:03pm
Brit Plumber
My old Focus Heated Screen lasted from the day I bought it in 2002 till the day I sold it for scrap in 2017, no loss at all. Not bad for a cheap and cheerful car. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #574568 Mon Feb 04 2019 10:28pm
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
When I first got the current car, mine was the same. Turned out to be a fuse. Worth a check. Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #574669 Wed Feb 06 2019 12:05pm
Wayneclarke
Really?? But the window does work just some sections don’t ! I will still have a check though
Post #574671 Wed Feb 06 2019 12:07pm
SuperC
My understanding is there is a fuse for each side so it could be that you have one bad side with dead elements but if the whole side is dead it may be a fuse. Of course, there could still be dead elements in that side too. Cheers,
Stuart.
Post #574676 Wed Feb 06 2019 12:23pm
