![]() | Home > Australia & New Zealand > Computer Reset after Battery Change |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Last Wednesday my 2011 RRS wouldn't start, flat battery. After a half hour on the charger it started and I drove to Galston about 45 minutes. Turned engine off and dash message comes up "Start engine immediately battery low". Rang LR assist and was given options but decided to drive to Concord Land Rover as the better option as car was running. At Concord LR battery came up OK so they wouldn't change it. (It obviously had a surface charge which they didn't test for.)
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
14.7 volts is ok if you still have problems then you need to look at your alternator, all the charging process is managed by the main ecu, this tells the alternator what charge to pump out when needed. Also a short drive will not charge a battery enough it has to charged for a couple of days to be fully charged.
Hi Flack,
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Barry are you a member of the AULRO forum, major weekend on the 24th/25th/26th Oct in terms of a meet up for
Hi Zilch,
