Home > Australia & New Zealand > Computer Reset after Battery Change
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Last Wednesday my 2011 RRS wouldn't start, flat battery. After a half hour on the charger it started and I drove to Galston about 45 minutes. Turned engine off and dash message comes up "Start engine immediately battery low". Rang LR assist and was given options but decided to drive to Concord Land Rover as the better option as car was running. At Concord LR battery came up OK so they wouldn't change it. (It obviously had a surface charge which they didn't test for.)
Next morning no go, so ring LR Assist again and they sent out an Allianz van with a replacement battery. Excellent service. Asked battery fitter if computer required a reset and he said probably not.
Anyway I have a GAP IID tool so did some checking on voltages and a computer reset with the following results.
New battery with no reset it charged at 14.7V, after computer reset the charge rate dropped to 14.1V. Both voltages after driving for about 20 minutes obviously with engine running. Note that the old battery charged consistently at 14.7Volts.
So clearly new battery would have been overcharging without a reset. Could explain a lot of early battery failures after replacement if no reset!
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #438148 Mon Sep 29 2014 8:00pm
flack
14.7 volts is ok if you still have problems then you need to look at your alternator, all the charging process is managed by the main ecu, this tells the alternator what charge to pump out when needed. Also a short drive will not charge a battery enough it has to charged for a couple of days to be fully charged.
The reason your charging value dropped was because you fitted a new fully charged battery.
Flack Thumbs Up
Post #438178 Tue Sep 30 2014 8:52am
Barryp
Hi Flack,
But it was 14.7 with the new battery and no reset and went to 14.1 volts the lower voltage after the reset with no other change.
The GAP IID instructions say that the reset is to clear the data in the computer memory which is held from the old battery.
Words from the GAP instruction manual below:
"-Battery Replacement
>> This routine will reset the stored battery monitoring data.
>> Use
>> This routine is required after the battery is replaced."
Regards
Post #438231 Tue Sep 30 2014 8:09pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Barry are you a member of the AULRO forum, major weekend on the 24th/25th/26th Oct in terms of a meet up for
the D3/D4/RRS brigade at Lake Lyell Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #438620 Mon Oct 06 2014 9:07am
Barryp
Hi Zilch,
Yes I am on AULRO and noted the thread but unfortunately can't make the Lake Lyell get together.
Regards
Post #438667 Mon Oct 06 2014 7:37pm
