Home > Wheels & Tyres > Winter season wheel change. |
jje Member Since: 03 Feb 2015 Location: essex Posts: 8 |
J have a set of 19inch original Range Rover Sport Snowflake designs rims on my 2008 TDV8 and it is fitted with Brembo brakes,original factory fit though, not 6 pot,hope this helps. |
Sun Oct 18 2015 9:41am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
You can definately fit 20".
Mon Oct 19 2015 7:03am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The later Y-spoke 19 also fits:
Mon Oct 19 2015 8:20am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Disco Milkey's D3 HSE wheel with Brembo 4-pots fitted:
Mon Oct 19 2015 9:30am |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Mon Oct 19 2015 8:59pm |
Trafalgar223 Member Since: 29 Apr 2011 Location: Dunfermline, Kingdom of Fife Posts: 26 |
Just a note on my experience with RRS Rim's;
Thu Oct 29 2015 12:37pm |
jjt57 Member Since: 24 Nov 2015 Location: aberdeen Posts: 5 |
I am new to this forum and RRS ownership - OK so I admit I used to drive a "hair dresser's" well I guess the pimp who owned the hairdressers Mk 1 Audi TT 3.2 V6 which I used to run on Vred Wintrac Extremes and enjoyed a spirited drive in any conditions that the Highlands threw at it - loads of grip etc. Last weekend we had the first real taste of winter and the RSS on 20 inch Scorpion Zero was useless in the slush wiggling around at the slightest hint of a push through corners and not in the least bit confidence inspiring. Apart from "don't expect a spirited drive slow down and enjoy the scenery" would downsizing to 19 inch wheels and fitting Vreds make a big difference over say just putting on 20 inch Vreds in terms of grip and handling ?? There is a piece on this at this link but is this juts a sales pitch or does the author really have a point ? http://whichtyres.com/2014/12/how-good-is-...he-winter/ |
Thu Nov 26 2015 8:50am |
You've said it yourself, but trying to 'push on' in 2.5 tonnes of high center of gravity RRS, will undoubtedly end unfavourably ON THE WAY: BMW F21 M140i
Thu Nov 26 2015 10:22am |
Thanks "beancounter" I absolutely understand the laws of physics and completely take the point about 2.5 ton of car etc BUT I would be more interested if anybody has a view, better still actual personal experience, in terms of replacing the 20 inch std Pirelli Scorps with smaller wheels and winter tyres vis a vis improved grip or indeed general handling. Before I shell out a wad of cash in the hope that it might actually make a difference. |
Thu Nov 26 2015 10:58am |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
I had a winter set of 19" wheels with Vreds for my first RRS. They were great. I couldn't get the car to skid when I tried hard in a near empty car park with snow and ice - felt totally in control. The problem was my insurer at the time insisted on classing it as a 'modifcation', wanted to know each time I swapped wheels and charged me for it.
Thu Nov 26 2015 11:13am |
Thanks "fkarim" been up those alpine roads myself a few times and frankly in anything without full caterpillar tracks you're going to have a few bottom puckering moments Good advice vis a vis insurer view I'll check that out and then depending on whether anyone else posts anything relevant perhaps it's as simple as does it make more sense to have a second set of wheels booted for winter or pay to have the winter/summer tyre shuffle which will probably be about 80 quid a pop !! |
Thu Nov 26 2015 11:53am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
I chose to get a second set of wheel and tyres for winter, 19" with Michelin winter tyres. I swapped them last weekend and I cannot believe the difference it made to the ride. I had no problems with the 20's but it is even smoother now. Swapping wheels is a hassle but I am also wary of damage to alloy rims when swapping just tyres. Each to their own though. |
Thu Nov 26 2015 11:59am |
I ran Vred Wintracs on 19s for three winters and they were pretty good. I'd certainly expect you to notice a world of difference from "summer" Scorpions, that's for sure. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 26 2015 10:41pm |
That article was obviously written by someone who hasn't a clue about the RRS1. 22 inch rims were never standard on the RRS1. However, the general premise that winter tyres will help in winter conditions is sound. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Nov 26 2015 10:47pm |
