Home > Faults & Fixes > Sticking rear caliper on s/c
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi all , I've got a sticking rear caliper on the nearside rear what are my options, can the caliper be refurbed or will it need replacing and discs and pads etc
Tia
Tony
Post #436488 Mon Sep 15 2014 9:41am
Disco_Mikey
For all they cost, you may as well replace the whole caliper:
http://www.advancedfactors.co.uk/c-tca3433...5-98-p.asp
FWIW, I had a sticky caliper on the back of my D3. Stripped it, cleaned and freed everything off. Seized up again a few months later Rolling Eyes
Post #436493 Mon Sep 15 2014 9:50am
Danny.H
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
I had a seized nearside rear the same as you, took it off thinking I'd be able to unstick it but nah she was to far gone, save the the heartache and get a new one. 2007 RRS 2.7 HSE - Java Black
Post #436498 Mon Sep 15 2014 10:06am
monty19
Thanks people Thumbs Up
Post #436502 Mon Sep 15 2014 10:23am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Are the calipers the same across the range or is there a difference between the models?
Siezed Drivers side rear! Grrrrrr!
Oh, and this may sound daft, but is the drivers side rear classed as left or right? Id say right... but that means Censored
Ta! Thumbs Up 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #470037 Mon Aug 10 2015 5:03pm
Yes, the UK driver's side is "right". They name the sides as if sitting in the car looking forward. 2012 SDV6 - it's missing a couple of cylinders
Post #470043 Mon Aug 10 2015 5:21pm
darrenmcneill
Thanks! 2006 HSE for Sale - £7,499 (Manchester)
Post #470046 Mon Aug 10 2015 5:32pm
darrenmcneill
The rear is sticking quite bad and I can't get the car into the garage til next week. The brake pad is smoking now because of the heat. Should I avoid driving or will it be ok? I'm guessing the pad will be screwed by the time the caliper is replaced? 2006 HSE for Sale - £7,499 (Manchester)
Post #470279 Thu Aug 13 2015 3:45pm
monty19
and the disc will warp because of the heat
Post #470857 Fri Aug 21 2015 5:50am
