![]() | Home > Faults & Fixes > Sticking rear caliper on s/c |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4454 ![]() ![]() ![]() |
For all they cost, you may as well replace the whole caliper:
Danny.H Member Since: 26 Aug 2014 Location: Brechin, Angus Posts: 91 ![]() ![]() ![]() |
I had a seized nearside rear the same as you, took it off thinking I'd be able to unstick it but nah she was to far gone, save the the heartache and get a new one. 2007 RRS 2.7 HSE - Java Black |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 ![]() ![]() ![]() |
Thanks people |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Are the calipers the same across the range or is there a difference between the models?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Yes, the UK driver's side is "right". They name the sides as if sitting in the car looking forward. 2012 SDV6 - it's missing a couple of cylinders
Thanks! 2006 HSE for Sale - �7,499 (Manchester)
The rear is sticking quite bad and I can't get the car into the garage til next week. The brake pad is smoking now because of the heat. Should I avoid driving or will it be ok? I'm guessing the pad will be screwed by the time the caliper is replaced? 2006 HSE for Sale - �7,499 (Manchester)
and the disc will warp because of the heat |
