![]() | Home > General > S/C Whining sound? |
paulrudd Member Since: 11 Nov 2012 Location: Doha Posts: 8 ![]() ![]() ![]() |
I had a similar problem, every time I hit 200KPH this annoying whining noise would start. The cure was to leave my wife at home |
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 ![]() ![]() |
It maybe the gearbox on the charger, these have straight cut gears. Is it the same sort of noise as when you give full acceleration? |
zacattack1845 Member Since: 03 Aug 2014 Location: Essex Posts: 25 ![]() ![]() ![]() |
Thanks for the response - in some ways its similar but what confuses me is that if I get the pedal in the right position the noise remains constant. |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Our cars do make this sound. It's normal. As pre mentioned its the charger. I love the sound. |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 ![]() ![]() ![]() |
Mine does it all the time, its the charger getting ready for hyper drive |
Kirbzz_11 Member Since: 11 Sep 2014 Location: Birmingham Posts: 24 ![]() ![]() |
Paul has killed me... Hahahah 😩 |
On the buyers guide on the forum it said this could be a front diff issue?
These cars are so complicated you can't really make a diagnosis on the net. Is there anyone local with a charged car that can compare? |
