Home > Faults & Fixes > Hawkeye Fault Code |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Which module? And what issues are you having? |
Thu Aug 28 2014 8:07pm |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 |
I think it was the parking module as the issue I've got is with the parking sensors not working, just trying to determine if its the loom or not
Thu Aug 28 2014 8:38pm |
That code is stored when the sensors have failed internally. Need to unplug them one by one, front and rear until the code disappears, and comes up with a fault for a sensor
Thu Aug 28 2014 8:54pm |
Are you suggesting a process of elimination directed at the sensors? I believe the pdc had already been swapped out to check (long story) |
Thu Aug 28 2014 9:03pm |
Right here's the deal folks; replaced the front & rear sensors and the looms as the rear was corroded, but the parking warning light still flashes and sounds a warning for 3 secs, I've plugged my hawkeye in and it's still showing the same fault code for front & rear: B1B57 Power circuit earth to ground, but won't clear the faults/ DTC's, is there a reset I need to do instead?
Sat Jun 06 2015 9:14pm |
problem fixed, ordered a used PDC Module from America £45 Inc postage
Tue Jul 28 2015 5:32pm |
