![]() | Home > Faults & Fixes > Hawkeye Fault Code |
Which module? And what issues are you having? |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 ![]() ![]() ![]() |
I think it was the parking module as the issue I've got is with the parking sensors not working, just trying to determine if its the loom or not
That code is stored when the sensors have failed internally. Need to unplug them one by one, front and rear until the code disappears, and comes up with a fault for a sensor
Are you suggesting a process of elimination directed at the sensors? I believe the pdc had already been swapped out to check (long story) |
Right here's the deal folks; replaced the front & rear sensors and the looms as the rear was corroded, but the parking warning light still flashes and sounds a warning for 3 secs, I've plugged my hawkeye in and it's still showing the same fault code for front & rear: B1B57 Power circuit earth to ground, but won't clear the faults/ DTC's, is there a reset I need to do instead?
problem fixed, ordered a used PDC Module from America £45 Inc postage
