Home > General > The creaking is still there !! |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 |
Anti roll bar bushes?? Just had mine done as it was creaking when the suspension went up and down, nothing while driving only noticeable when at a standstill. If it is that make sure you get the later spec ARB clamps fitted too. LR dealer identified the problem in 2 minutes, have your workshop visits been to LR or another garage - did you go in for the creaking originally, guess if the lower arms needed changing that could have masked a problem with the roll bar bushes. TDV8 Java Black, Overfinch 22s |
Thu Aug 28 2014 4:50am |
Morepower Member Since: 26 Aug 2014 Location: Somerset Posts: 13 |
Mine was creaking, it was the arb bushes too |
Thu Aug 28 2014 5:21pm |
Spray your Anti-rollbar bushes (one at a time) with silicon lubricant or WD40 if 'creaking' noise stops you'll know exactly which bush it is. |
Thu Aug 28 2014 5:33pm |
