Home > General > The creaking is still there !!
Lewis
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Stornoway Grey
After two visits to the workshop - 4 new tyres, 4 new disk and pads 2 new front lower arms and endless wheel balancing I still seam to have a creaking sound from the front end sounds like another worn bush but which one? any help would be appreciated Thumbs Up
Post #434368 Wed Aug 27 2014 11:11pm
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Anti roll bar bushes?? Just had mine done as it was creaking when the suspension went up and down, nothing while driving only noticeable when at a standstill. If it is that make sure you get the later spec ARB clamps fitted too. LR dealer identified the problem in 2 minutes, have your workshop visits been to LR or another garage - did you go in for the creaking originally, guess if the lower arms needed changing that could have masked a problem with the roll bar bushes. TDV8 Java Black, Overfinch 22s
Post #434372 Thu Aug 28 2014 4:50am
Morepower
England 2007 Range Rover Sport TDV8 HSE Rimini Red
Mine was creaking, it was the arb bushes too
Post #434409 Thu Aug 28 2014 5:21pm
drdelrrs
Spray your Anti-rollbar bushes (one at a time) with silicon lubricant or WD40 if 'creaking' noise stops you'll know exactly which bush it is.
Post #434411 Thu Aug 28 2014 5:33pm
