Home > General > arghh - repeated flat battery after holiday
redson
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Bought my TDV8 in March - not a single problem.
Just come back from two weeks holiday during which the car was sat in a field somewhere with a valet parking company.
When it was dropped off to me the clocks were all zeroed which I put down to the fact that they had sensibly disconnected the battery while we were away.
Since then the battery is flat every morning with all sorts of weird clicks etc when i try and start the ignition. The comp may assures me they did NOT disconnect the battery.
Is there anything that would drain the battery if left standing over two weeks? Mad TDV8 2007 window tints, Logic 7, side steps.
Post #433221 Thu Aug 14 2014 6:26pm
Chin
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Just got mine back from being sat at Gatwick for 2 weeks.
Started fine no probs.
Sounds like dodgy battery or alt
Post #433222 Thu Aug 14 2014 6:40pm
shakeapaw
I read somewhere, that if your going on holiday for two weeks or more you put the car into a deep sleep, turn off the auto lights and wipers, and put suspension into access mode. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #433256 Thu Aug 14 2014 11:38pm
shakeapaw
Post #433257 Thu Aug 14 2014 11:39pm
mlines
The car automatically goes into a deep sleep after a period of time (two days?) I think you can make this happen quicker by parking it in Access Mode.
There used to be an issue with previous Range Rover models that local radio interference (cellular towers) would prevent them sleeping and flatten the battery, perhaps this "field" is near some powerful transmitters.
Alternatively perhaps the car parking company operates a second hand parts shop and has swapped your battery for a dud one! (Not so far fetched, happened at Heathrow in the 1980's when I worked there) 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #433274 Fri Aug 15 2014 10:42am
simple1
Common issue with Range Rovers. Mine did this until I installed an inteli-charger. If I left it at airports, I always took a booster pack in the boot, never use jump leads without a surge protector!!!
I tried switching everything off and leaving in access mode but battery went flat anyway. Battery should charge but if it's old it may well have a dead cell if it won't hold charge over night. Although extremely expensive, only fit a genuine LR replacement, all sorts of horror stories on here about cooked alternators and wiring faults with none genuine batteries Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #433327 Fri Aug 15 2014 10:19pm
