Home > Technical > What's the legal towing limit on rrs?
alexwilson86
Hi all I'm looking into buying a rrs just wondering what the Towing limit of a rrs? Gross train weight? as I do a lot of winch challenge and need it to tow my truck.
Thanks.
Post #432227 Sun Aug 03 2014 11:39am
Andi
A bit here;
http://www.rrsport.co.uk/forum/topic33113....wing+limit
Post #432234 Sun Aug 03 2014 12:36pm
The vehicle is rated to tow 3500kg with a nose weight of 150kg (in the UK) which was reduced from the earlier nose weight of 250kg.
Max unladen weights:
Petrol engine vehicles (NA) 2 480 - 2 485 kg
Petrol engine vehicles (SC) 2 572 - 2 614 kg
Diesel engine vehicles 2 455 - 2 479 kg
Gross vehicle weights:
Petrol engine vehicles (NA) 3 070 kg
Petrol engine vehicles (SC) 3 125 kg
V6 Diesel engine vehicles 3 070 kg
V8 Diesel engine vehicles 3 175 kg
Maximum front axle load:
All vehicles 1 470 kg
Maximum rear axle load:
All vehicles 1 710 kg
Gross Train Weight:
(Weight of vehicle plus trailer with overrun brakes)
Petrol engine vehicles (NA) 6570 kg
Petrol engine vehicles (SC) 6625 kg
Diesel engine vehicles 6570 kg 2012 SDV6 - it's missing a couple of cylinders
Post #432235 Sun Aug 03 2014 12:50pm
alexwilson86
I'm sure someone told me that it wasn't 3.5t (2.7 rings a bell)
But hopefully there wrong 😃 can anyone one tell me the weights stated on the vin plate. Or take a pic with the vin number covered
Pref of a 2.7tdv6 around 06-07
Thanks.
Post #432239 Sun Aug 03 2014 1:38pm
They are all 3.5 tonne towing capacity. The only modern Land Rovers that aren't 3.5 tonne are the Freelander/Evoque. Unless the hybrids are different. 2012 SDV6 - it's missing a couple of cylinders
Post #432267 Sun Aug 03 2014 9:16pm
alexwilson86
Thanks to all that have replied. Let the hunt begin 😃
Post #432268 Sun Aug 03 2014 9:23pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
so if im towing something that's 3000 kg and trailer weighs 500 kg =3500 and rrs weighs 3000 = 6500 total is this aloud ??? 2007 COOLRRS
Post #433333 Fri Aug 15 2014 11:32pm
I think so, yes, because the RRS is less than the GVW and the trailer + load is within the rated towing limit. The two together are less than the gross train weight. 2012 SDV6 - it's missing a couple of cylinders
Post #433338 Sat Aug 16 2014 12:00am
shadrack
i had 3.5t on mine the other day and it towed it a dream compared to my transit...
Post #433368 Sat Aug 16 2014 5:30pm
SRE
Spain
a) You need the correct licence
b) Size does matter (or so I have heard Whistle )
c) Finally, make sure that what you tow is for Private use (and that you can prove it) else you will require a tachograph
A simple guide
https://www.gov.uk/towing-with-car/driving...ou-can-tow In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #433465 Sun Aug 17 2014 10:03am
