Home > Technical > What's the legal towing limit on rrs? |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
A bit here;
Sun Aug 03 2014 11:36am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
The vehicle is rated to tow 3500kg with a nose weight of 150kg (in the UK) which was reduced from the earlier nose weight of 250kg.
Sun Aug 03 2014 11:50am |
alexwilson86 Member Since: 27 Jul 2014 Location: leicester Posts: 15 |
I'm sure someone told me that it wasn't 3.5t (2.7 rings a bell)
Sun Aug 03 2014 12:38pm |
They are all 3.5 tonne towing capacity. The only modern Land Rovers that aren't 3.5 tonne are the Freelander/Evoque. Unless the hybrids are different. 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 03 2014 8:16pm |
Thanks to all that have replied. Let the hunt begin 😃 |
Sun Aug 03 2014 8:23pm |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 |
so if im towing something that's 3000 kg and trailer weighs 500 kg =3500 and rrs weighs 3000 = 6500 total is this aloud ??? 2007 COOLRRS |
Fri Aug 15 2014 10:32pm |
I think so, yes, because the RRS is less than the GVW and the trailer + load is within the rated towing limit. The two together are less than the gross train weight. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 15 2014 11:00pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
i had 3.5t on mine the other day and it towed it a dream compared to my transit... |
Sat Aug 16 2014 4:30pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
a) You need the correct licence
Sun Aug 17 2014 9:03am |
