Home > Technical > Retractable rear load cover problem
Siddharthaoke
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Galway Green
The load cover on my 2010 sport does not fit properly. It seems a little too short and doesn't fit into the recesses at the back of the boot. Does anyone know if there are two different load covers for pre and post 2010? Or is there some adjustment that I am missing?
Thanks in advance
Sid
Post #431021 Sun Jul 20 2014 9:52am
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
is there a difference between the FF and the RRS ones? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #431023 Sun Jul 20 2014 10:59am
Siddharthaoke
Sorry to bump this. Anyone know if there are different load covers or why mine doesn't seem to fit well.
Sid
Post #432070 Thu Jul 31 2014 10:13pm
vin297
hi,
I think I may be able to help with this as I had the same problem, has the car ever had a dog guard fitter? the reason I ask if the dog guards push the side panels in and therefore the load cover it too short. if you see where the side panels meet the quarter window and pillar trim does it all line up correctly?
Post #432085 Fri Aug 01 2014 9:40am
Siddharthaoke
Brillant. Had a look and discovered the side panel on the offside was slightly looser than on the near side. On stripping it out, discovered that clearly this panel had been off before and half the retaining clips were broken. 3 new clips for a fiver and 20 mins work and the panel is now fitted properly, and the load cover fits better. Not quite as snug a fit as I would expect but better and it doesn't fall down.
Thumbs Up vin297
Post #432112 Fri Aug 01 2014 5:41pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
I now know why my rear load cover seems a bit short.................. Or should I say the panels are pushed apart.
Dog Guard ! !
Good post............... Thumbs Up Thumbs Up
Post #432113 Fri Aug 01 2014 5:45pm
vin297
no worries, this a excellent forum where I have received heaps of help, so its only fair that I do my bit!!!
Post #432119 Fri Aug 01 2014 6:16pm
Russben
I've been wondering why mine doesn't seem to fit properly too. I'll have a look to see if a dog guard was fitted at some point.
Thanks for the info, much appreciated. I'm in the shed, I'll be back in the real world in a minute.
Post #433661 Mon Aug 18 2014 8:48pm
stealth
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
I concur with the dog guard theory
Post #437146 Sat Sep 20 2014 10:30am
