Home > Technical > suspension fault normal ride height only
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
hi all, im offshore at the moment and mrs montys getting this fault up on the car, it resets for a while when its turned off but keeps coming back.
the car drives fine but stays in normal height mode, any ideas or links to this issue
all advise welcome
Post #430779 Thu Jul 17 2014 8:47am
edvarski
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I had this happen last year. It comes and goes for a while then steadily gets worse. It was a slow leak in the air suspension system. I can't remember whether they just replaced the hose or needed a new compressor, but as it was under extended warranty I didn't enquire too much.
Probably worth a trip to the dealers to confirm.
Post #430780 Thu Jul 17 2014 9:18am
most likely compressor/leaky valve issues.
However, bad tracking also triggered this error with my 2007 TDV8 so you never know it might not be too expensive! RRS gone
Post #431131 Mon Jul 21 2014 11:29am
jack.bauer
Had the same as above. Mine eventually required compressor replaced. 07 TDV8 + BAS map
Post #431626 Fri Jul 25 2014 6:44pm
