You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Technical > suspension fault normal ride height only
monty19
hi all, im offshore at the moment and mrs montys getting this fault up on the car, it resets for a while when its turned off but keeps coming back.
the car drives fine but stays in normal height mode, any ideas or links to this issue
all advise welcome
Thu Jul 17 2014 7:47am
edvarski
I had this happen last year. It comes and goes for a while then steadily gets worse. It was a slow leak in the air suspension system. I can't remember whether they just replaced the hose or needed a new compressor, but as it was under extended warranty I didn't enquire too much.
Probably worth a trip to the dealers to confirm.
Thu Jul 17 2014 8:18am
most likely compressor/leaky valve issues.
However, bad tracking also triggered this error with my 2007 TDV8 so you never know it might not be too expensive!RRS gone
Mon Jul 21 2014 10:29am
jack.bauer
Had the same as above. Mine eventually required compressor replaced.07 TDV8 + BAS map
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
