![]() | Home > Technical > How to use coordinates for sat nav |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
Not sure how you input minus or West without looking at the manual.
gwengler Member Since: 19 Aug 2013 Location: Toronto Posts: 19 ![]() ![]() |
You need to convert to degrees - minutes seconds. For example here: http://transition.fcc.gov/mb/audio/bickel/DDDMMSS-decimal.html - minus means West. Gerd |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 ![]() ![]() ![]() |
Thank you Gwenler, how the flipping eck do you know that? Will put the new values in tonight and see where it takes me |
Sorry for the mistake on the name Gwengler MY 13 3.0 SDV6 HSE Black Edition
Hopefully, it will take you to Rathaspeck Manor. Looks gorgeous!
I've tried the converter. And it the result was Lat 52, 18.16.236 Lon -6 29 36135 but my sat nav will only allow 6 digits !!!! I must be doing something wrong ??? |
No problem. Just round the seconds. The coordinates for you should be as follows:
Thanks again, just put the numbers in at its now found it. Again thank you |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Change the country on the sat~nav to Ireland. I have had no problem when there. Great pint of Guinness. |
