Home > Maintenance & Modifications > Gearbox mega flush or filter change ?
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
What's the difference between a full mega flush AND a filter change with oil drain ? Or technically are they as good as each other ? I'm hearing people saying they have had a mega flush BUT not saying they have had the filter changed ?
Post #429592 Mon Jul 07 2014 5:06pm
Disco_Mikey
The filters are still clean, even after 150k miles.
A "megaflush" is the way to go
A drain and refill with oil only changes 4 litres or so of old oil
A double flush will replaces 6.5 litres
A "megaflush" is the only way to replace the full 11 litres of oil in the gearbox
Post #429593 Mon Jul 07 2014 5:14pm
J.blase
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Mega flush
What sort of money is a mega flush thanks john.
Post #429594 Mon Jul 07 2014 5:24pm
sestorious
I've found a firm called Quattro auto care in York that does the mega flush for £260. Disco mikey, so the filter DEFO doesn't need changing ??? I've got 112000 miles on my RRS. No real problems tbh slight shunt etc more of a preventative plan than anything else !
Post #429595 Mon Jul 07 2014 5:33pm
shadrack
keep me in the loop if you use quattro as im from whitby and found there details, mines going into a local indy tomorrow for an oil service, wheel aligment and a diagnostic check, they quoted £520+vat to change gearbox oil and filter so i said no, however im after a flush as im on 130k miles now.
is £260 inc vat
thanks
Post #429607 Mon Jul 07 2014 6:32pm
Stuart
There are a couple of indys on here that do tours all over the place and will do it without VAT. How mine got done.
Post #429608 Mon Jul 07 2014 6:35pm
shadrack
i was after that tour, i missed the one a while ago that was at weatherby services however i think it was around £300 i may be wrong tho
Post #429610 Mon Jul 07 2014 6:38pm
sestorious
Shad rack yes that's including VAT ! I'm just waiting for a bit more info from disco mikey as to why the filter doesn't need changing ? Surely it's full of c**p after 112000 miles ? I think 260 inc is a good price but can't compare it as I've never had this done before !
Post #429611 Mon Jul 07 2014 6:41pm
shadrack
ive also never had it done but i thought i had a gearbox issue a few months ago which turned out to be a odd tyre and not the box, however since then i thought a megger flush could be needed for piece of mind, so how about we both contact them and see if they do a little forum discount say book mine and yours in and do them at £230 each? or get 5 of us and see if they do £200
Post #429613 Mon Jul 07 2014 6:46pm
sestorious
I'd be more than willing to see if we can strike a deal with them if anyone else was willing ?
Post #429616 Mon Jul 07 2014 6:58pm
Disco_Mikey
Mine had that shunt. Gearbox oil and filter done at 114,650 miles
Shunt was always present. Gearchanges were a bit slow
Remap has amplified these issues, and now 5th gear is Censored
Post #429633 Mon Jul 07 2014 7:47pm
sestorious
So a straight mega flush will be fine then mate ? When you did yours did you see the oil that came out ? Was it very dirty ? Have you noticed a difference ? Cheers
Post #429634 Mon Jul 07 2014 7:51pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Double flush and dr tranny all day long silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #429643 Mon Jul 07 2014 8:11pm
sestorious
Dr tranny ? That is also available with this mega flush wat does that do ?
Post #429654 Mon Jul 07 2014 8:33pm
Disco_Mikey
Yes, the oil was very black, and very smelly!
I can't say I noticed a difference as I had not driven the car by this point. I bought it as a non runner
However, at 115k miles, the damage had already been done. The box needs flushed every 60-75k as advised by the gearbox manufacturer
Post #429677 Mon Jul 07 2014 9:41pm
