![]() | Home > Maintenance & Modifications > Gearbox mega flush or filter change ? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
The filters are still clean, even after 150k miles.
J.blase Member Since: 01 Jan 2014 Location: Essex Posts: 24 ![]() ![]() ![]() |
What sort of money is a mega flush thanks john. |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 ![]() ![]() ![]() |
I've found a firm called Quattro auto care in York that does the mega flush for £260. Disco mikey, so the filter DEFO doesn't need changing ??? I've got 112000 miles on my RRS. No real problems tbh slight shunt etc more of a preventative plan than anything else ! |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
keep me in the loop if you use quattro as im from whitby and found there details, mines going into a local indy tomorrow for an oil service, wheel aligment and a diagnostic check, they quoted £520+vat to change gearbox oil and filter so i said no, however im after a flush as im on 130k miles now.
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
There are a couple of indys on here that do tours all over the place and will do it without VAT. How mine got done. |
i was after that tour, i missed the one a while ago that was at weatherby services however i think it was around £300 i may be wrong tho |
Shad rack yes that's including VAT ! I'm just waiting for a bit more info from disco mikey as to why the filter doesn't need changing ? Surely it's full of c**p after 112000 miles ? I think 260 inc is a good price but can't compare it as I've never had this done before ! |
ive also never had it done but i thought i had a gearbox issue a few months ago which turned out to be a odd tyre and not the box, however since then i thought a megger flush could be needed for piece of mind, so how about we both contact them and see if they do a little forum discount say book mine and yours in and do them at £230 each? or get 5 of us and see if they do £200 |
I'd be more than willing to see if we can strike a deal with them if anyone else was willing ? |
Mine had that shunt. Gearbox oil and filter done at 114,650 miles Shunt was always present. Gearchanges were a bit slow Remap has amplified these issues, and now 5th gear is ![]() |
So a straight mega flush will be fine then mate ? When you did yours did you see the oil that came out ? Was it very dirty ? Have you noticed a difference ? Cheers |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Double flush and dr tranny all day long silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Dr tranny ? That is also available with this mega flush wat does that do ? |
Yes, the oil was very black, and very smelly! I can't say I noticed a difference as I had not driven the car by this point. I bought it as a non runner However, at 115k miles, the damage had already been done. The box needs flushed every 60-75k as advised by the gearbox manufacturer |
