![]() | Home > General (L494) > TPMS Fault |
ewerdl Member Since: 28 Sep 2012 Location: In the kitchen, usually, by iPad. Posts: 12 ![]() ![]() |
Mine cleared itself after a "reboot" (off, then on again). |
Fin Member Since: 05 Jan 2014 Location: Renfrewshire Posts: 29 ![]() ![]() |
Mine cleared too. Only happened once,in the 4 months I have had the car. |
The Red One Member Since: 30 Jun 2012 Location: Somerset Posts: 53 ![]() ![]() |
Had this message too, it looks like a common fault. Contacted LR assist and advised to check the tyre pressures and contact the dealer. It seems to have cleared itself as the pressures are fine, but is will get the dealer to check. |
Peterlondon Member Since: 14 May 2014 Location: Bucks J5 M40 Posts: 80 ![]() ![]() ![]() |
Thanks everyone.
James @ Grange Barnet LR Member Since: 17 Oct 2012 Location: Barnet, North London Posts: 208 ![]() ![]() ![]() |
Hi Peter,
James thanks for that helpful reply.
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
I had a similar problem on my Jag XF, ended up having to have the TMPS module replaced, under warranty thankfully. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Following the procedure suggested by James resolved the problem I had last week.
So one week one with the new 20" wheels and they seem to have fully paired with the cars TPMS system and are now giving me what look like sensible readings from each wheel on the dashboard screen. MY2010 TDV8 purchased Jan 2017
