Home > Faults & Fixes > 2007 TDV8 FRONT BRAKE SQUEAL (BREMBO)
austencameron
at my wits end with these brakes, had no noise until I fitted new discs and pads (genuine brembo).
the squeal appears at low speeds and reverse.
ive tried copper grease
no grease
a lover grade brake pad set
ive done 1000 miles and still the same
etc
etc
any help would be gratefully appreciated before I throw a hammer at it!
Post #427169 Sat Jun 14 2014 6:27pm
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
mine does it, not sure what the solution is, ive found a couple of high speed runs and jump on the brakes hard seems to clear it for a while
Post #427170 Sat Jun 14 2014 6:36pm
tommo1975
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Some brembo calipers have antisqueal shims ,seen it on subaru brembo's but not sure about range rover calipers-best ask a local main dealer.
Post #427171 Sat Jun 14 2014 6:39pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Yep ^ anti squeal shims will work. Decent brake seller will do them Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #427188 Sat Jun 14 2014 8:18pm
Disco_Mikey
Never used anti-squeal shims on Brembo calipers before. Never squeaked before...
Is it definately coming from the front, and not from a binding rear caliper, or EPB. Or even the backplate rubbing against the disc Question
Post #427211 Sat Jun 14 2014 10:53pm
austencameron
no! and still driving me round the twist! ive tried every thing apart from new discs.... but these ones have only done 5k miles and the squeal was there from the word go Big Cry
Post #451393 Thu Feb 05 2015 2:40pm
Advanced Factors
Site Sponsor
Have come across this over on the full fat forum, squeal on Brembo calipers can be fixed by changing the pin and spring kit, these seem to loose tension.
Is it fair to assume that the new discs were de-greased before fitting? I have had a pair back before for "warranty" that were brown coloured where the protective coating was burnt on. sorry for asking, just needs to be ruled out. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #451416 Thu Feb 05 2015 4:29pm
austencameron
thanks for the info, ruled this out prior to fitting and many time after, my pins and clip seem to have really good tension but can try this Thumbs Up
Post #451429 Thu Feb 05 2015 5:45pm
Advanced Factors
Site Sponsor
If they were from me happy to swap the pads if you think they are iffy, although Brembo stuff is usually 100% everytime. Paul Redding
+44 (0)23 8052 2776
Post #451430 Thu Feb 05 2015 5:59pm
austencameron
gen brembo gear, I even tried a cheaper pad to try and see if the softer option would work! Big Cry
Post #451535 Fri Feb 06 2015 9:18am
