![]() | Home > Faults & Fixes > 2007 TDV8 FRONT BRAKE SQUEAL (BREMBO) |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 ![]() ![]() ![]() |
mine does it, not sure what the solution is, ive found a couple of high speed runs and jump on the brakes hard seems to clear it for a while |
tommo1975 Member Since: 15 Mar 2014 Location: scotland Posts: 12 ![]() ![]() ![]() |
Some brembo calipers have antisqueal shims ,seen it on subaru brembo's but not sure about range rover calipers-best ask a local main dealer. |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Yep ^ anti squeal shims will work. Decent brake seller will do them Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Never used anti-squeal shims on Brembo calipers before. Never squeaked before...
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 ![]() ![]() ![]() |
no! and still driving me round the twist! ive tried every thing apart from new discs.... but these ones have only done 5k miles and the squeal was there from the word go |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
Have come across this over on the full fat forum, squeal on Brembo calipers can be fixed by changing the pin and spring kit, these seem to loose tension.
thanks for the info, ruled this out prior to fitting and many time after, my pins and clip seem to have really good tension but can try this |
If they were from me happy to swap the pads if you think they are iffy, although Brembo stuff is usually 100% everytime. Paul Redding
gen brembo gear, I even tried a cheaper pad to try and see if the softer option would work! |
