![]() | Home > Faults & Fixes > Access mode |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
Dropping the vehicle only requires air to be vented from each strut by way of the corner valves. The compressor is a red herring I think. Could be a corrupt suspension calibration or just a height sensor that is on its way out. You need to have the fault codes read for a start. This might point you in the correct direction. 2012 SDV6 - it's missing a couple of cylinders
customcarsuk Member Since: 15 Mar 2013 Location: west midlands Posts: 76 ![]() ![]() |
Thanks Pal.
