Home > Faults & Fixes > Access mode |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
Dropping the vehicle only requires air to be vented from each strut by way of the corner valves. The compressor is a red herring I think. Could be a corrupt suspension calibration or just a height sensor that is on its way out. You need to have the fault codes read for a start. This might point you in the correct direction. 2012 SDV6 - it's missing a couple of cylinders
Wed Jun 11 2014 11:15pm |
customcarsuk Member Since: 15 Mar 2013 Location: west midlands Posts: 76 |
Thanks Pal.
Tue Jun 17 2014 11:15pm |
