Home > Technical > TDV8 lack of power & excessive fuel consumption problem
rangieroveres
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Fuji White
Hi, hoping someone may have some ideas on the problem I have with my TDV8 as it's only doing 16mpg & doesn't pick up like it should... Occasionally it will go into restricted performance mode & I have to stop & start engine again to be able to continue & after this happens I get the fault code P023D manifold absolute pressure correlation bank A... Doesn't really smoke maybe a slight bit on hard acceleration from the R/H exhaust...
I have changed the Map sensors, swapped the air flow meters from another one, checked the turbo actuator rods & they move with ease & have inspected all the intake hoses...
It's a 2010 model & only done 50k so shouldn't be the turbo's I hope!
Any ideas would be much appreciated...
Post #426061 Tue Jun 03 2014 1:24am
Disco_Mikey
Maybe stating the obvious, but have you removed the top turbo hoses, and checked them for splits?
Post #426120 Tue Jun 03 2014 5:15am
rangieroveres
Yes checked all the induction pipes & also ran the engine with the top hoses off & they were blowing at a reasonable force even when putting my hand over each... I have compared it with another TDV8 & it's not running as smooth on idle & the pickup when you rev isn't as sharp... Thought maybe EGR related though would the computer not come up with a fault on that if it were to do with that?
Post #426130 Tue Jun 03 2014 6:26am
Camelrock
Is there problem with one of the cats ?? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #426189 Tue Jun 03 2014 9:26pm
rangieroveres
Yes I was thinking of dropping the downpipes & taking it for a spin see if it made any difference... Quite low milage for that to be a problem I would have thought but maybe it spent it's life doing short trips & never getting blasted out.. Will give it a go though thanks...
Post #426199 Tue Jun 03 2014 10:09pm
Disco_Mikey
All symptoms of a boost leak. Did you physically check the hoses all over, inc under the mesh bits?
Wouldnt be the first time a garage has called me out to look at a car as they have missed it
And split hoses are a fairly common issue, whereas blocked cats are not...
Post #426211 Wed Jun 04 2014 4:49am
rangieroveres
Had the car go into limeted performance twice yesterday on my way home so plugged it in to laptop as I have the same setup as Land Rover with Torpix & got the same fault P023D-22 but it gave me the option of doing a Manifold absolute pressure MAP sensor test that I did... It came back with the sensor bank 1 falioure or wiring harness fault or the engine ecu is faulty & as I have changed the sensor & checked the wiring back to the ecu I'm wondering if it could be the ecu... I downloaded the latest software onto the engine ecu though that hasn't made any difference... The ecu is over a grand though so not something I want to change unless certain! I do have another TDV8 so could maybe swap the ecu though not sure that will work as it has to be programmed with vin num etc!?
Post #426574 Sun Jun 08 2014 5:17pm
Disco_Mikey
Highly unlikely to be an ECU. I would double check all of the turbo hoses, intercooler for leaks, and the actuators for free movement
Otherwise, replacing parts with guesswork will end up getting expensive.
At this point, I would have to advise taking the car to an indy or a dealer. Much cheaper in the long run to spend a little on diagnostics than throwing parts at the car
Post #426594 Sun Jun 08 2014 9:49pm
