Home > General > Refused Warranty Claim - Thoughts? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8940 |
Have you tried the LandRover button on your key fob? It's programmable - mine is set to release the upper hatch (this was presumably set by the previous owner). You might be lucky and find that it works. Alternatively, you can pull the rubber cover off of the switch and have a look inside. If the spring is corroded you might still be able to press the microswitch directly. It is, according to others on the forum, possible to remove the switch in this situation by careful use of a thin blade pushed down the (short) sides of the switch. You can then remove the switch and plug the new one in to the loom. You should then be able to release the hatch and finish the job with easier access. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Jun 02 2014 6:07pm |
