Home > General > Refused Warranty Claim - Thoughts?
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
[quote]Buy a new switch
Pop old switch out the hole
Unplug old switch, and plug in new switch
Check to see if it works.
If it does work, clip the new switch back in
[quote]
this is what i did , £20 on fleabay & 5 minutes to do
Post #425908 Sun Jun 01 2014 7:46pm
Chomega wrote:
Alternatively, is there any OTHER way to open the tailgate glass?
Have you tried the LandRover button on your key fob? It's programmable - mine is set to release the upper hatch (this was presumably set by the previous owner). You might be lucky and find that it works.
Alternatively, you can pull the rubber cover off of the switch and have a look inside. If the spring is corroded you might still be able to press the microswitch directly. It is, according to others on the forum, possible to remove the switch in this situation by careful use of a thin blade pushed down the (short) sides of the switch. You can then remove the switch and plug the new one in to the loom. You should then be able to release the hatch and finish the job with easier access. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #426003 Mon Jun 02 2014 5:07pm
