Home > Technical > oil light flashing
suzukiboy
oil light flashing
hi people not sure if its a problem or not really ,had oil changed on my 2005 rrs basically an engine service ,but since ive noticed when i start the car the oil light seems to flash for quite a while before going of maybe flashes about 8 - 10 times ,have checked the oil and levels are fine ,any help would be greatly appreciated
Post #424534 Fri May 16 2014 9:35pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
i would check its the correct grade ,and check the oil filter has been fitted correctly as the y can be a bit of a pain,i would not drive it ,it has just cost me nearly 3k to build my own engine Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #424541 Sat May 17 2014 5:56am
Bodsy
Site Sponsor
Don't drive it. Double check the oil they used. More importantly, double check the oil filter,it may be that they used a cheap copy oil filter. There have been many stories of failures due to poorly fitted or poor quality non genuine filters. Seriously get it check before you drive it. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #424728 Mon May 19 2014 10:16pm
jochem00
Did you find the solution?
Do you have the TDV6? How about oilpressure?
Post #426740 Tue Jun 10 2014 2:39pm
