![]() | Home > Technical > oil light flashing |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i would check its the correct grade ,and check the oil filter has been fitted correctly as the y can be a bit of a pain,i would not drive it ,it has just cost me nearly 3k to build my own engine |
Don't drive it. Double check the oil they used. More importantly, double check the oil filter,it may be that they used a cheap copy oil filter. There have been many stories of failures due to poorly fitted or poor quality non genuine filters. Seriously get it check before you drive it. |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
Did you find the solution?
