Home > General > Tow bar stuck ???
rterryc4
Tow bar stuck ???
Just tried to remove the tow bar from my TDV8 to put it back in the boot and I can't get it to release. The tow bar has been on there for a while, and it's definitely unlocked as I can pull the free handle out and rotate it through 180 degrees, but when I do this, the tow bar doesn't release from the housing and drop out. Are there any tips for getting it to release, or do I need a trip to the dealers for them to give it a tap with hammer Laughing
Cheers,
RT
Post #423536 Wed May 07 2014 3:32pm
WD40 and a rubber mallet are your friends Wink ON THE WAY: BMW F21 M140i
Post #423539 Wed May 07 2014 3:46pm
rterryc4
Cheers, will give that a try Thumbs Up
Post #423540 Wed May 07 2014 4:13pm
rterryc4
... and it worked like a charm !
Cheers Thumbs Up Thumbs Up
Post #423542 Wed May 07 2014 4:39pm
simple1
Resist the temptation to drown everything in grease, the track gets gummed up with gravel and silt if you do Embarassed
Give the locking mechanism good soak in WD and wrap the neck up in a bag when you store it under floor to save the foam liner . Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #423566 Wed May 07 2014 6:56pm
