Home > In Car Electronics > Sat nav women stopped talking to me
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi guys, satnav stopped talking any ideas ? It shows map and highlights which way but no vocal instructions.
It's a 2006 hse, thanks in advance, Rich
Post #423418 Tue May 06 2014 7:17pm
Bungleaio
2005 Range Rover Sport Supercharged Buckingham Blue
did you turn the volume down whilst she was talking?
From memory there is a button bottom right of the screen when you have the map up and a route active, this will make the lady talk to you, if you use the volume control for the radio whilst she is talking you can turn her up.
There is also another option through the main menu to make her talk but I can't remember the exact steps as I'm pretty new to RRS ownership. If you are still struggling I will figure it out for you as I did it on mine the other day.
Post #423441 Tue May 06 2014 8:44pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
rich.
When navigating, look in the lower right corner.
There is a symbol of a speaker, is it crossed or not?
If it is crossed, press the "return" arrow up in the corner,
and then on the next screen, press the "uncrossed" speakersymbol
in the lower right.
Then it ought to be sorted.
If not, in the extended menu (if i recall this correctly, press info) in the stereo,
You can check, and adjust the navigation speaker
offset to your desired level.
hopefully this is of some help..
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #423462 Tue May 06 2014 10:11pm
rich_z3
Thanks guys sorted now it was muted and turned right down, all back to normal now sending me the wrong way as usual. Rich
Post #423548 Wed May 07 2014 4:59pm
simbad111
just got 2014 sat nav disc from web company for £30 works great, up to date streets and gets you where you want to go
Post #423691 Thu May 08 2014 6:11pm
scarey
that'll be a pirated copy which is frown upon here..
Post #423698 Thu May 08 2014 7:20pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Definately frowned upon..........Where did you get it?? Thumbs Up Thumbs Up
Supporting the London Air Ambulance with my Brothers
Post #423753 Fri May 09 2014 10:07am
Howler
England 2005 Range Rover Sport Supercharged Buckingham Blue
I'Ve heard about these updates Whistle I wonder if it's the one's from oh what's that forrest called the ama, the ama, erm, zon something or other Twisted Evil
regards
Howler
Post #423757 Fri May 09 2014 10:45am
tanloverluke
is it? only by the goody two-shoes! if it works it's a "steal" at £30 Mr. Green. does it work, simbad111, without any faults? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #423765 Fri May 09 2014 11:56am
Howler
Er can't be the forrest that's only £18.98 inclusive of p&p Mr. Green and that one works perfect Laughing so I understand Whistle
Regards
Howler
Post #423766 Fri May 09 2014 12:24pm
