Home > Technical > Varying ride height
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Varying ride height
I am still learning from the wealth of information on this forum. When looking at ads, some RRS' look like the suspension is very low and others very high. I understand that it can manually be adjusted, but can it be driven at varying heights?
Personally, I think it looks odd in the 'high' setting but looks awesome in the 'low' setting - Can it be driven in the 'low' setting?
(Picture shows one with 22" Alloys)
Post #422887 Wed Apr 30 2014 6:17pm
C11RRJ
England 2007 Range Rover Sport TDV6 HSE Java Black
They can be driven in access mode and off road mode below 19mph, anything above that then it goes into standard drive height mode 👍
Post #422889 Wed Apr 30 2014 6:23pm
micalee
Presume then the 'high' picture is standard setting then
Thanks
Post #422891 Wed Apr 30 2014 6:38pm
Disco_Mikey
They can be driven "low", if the suspension heights have been altered, using the correct diagnostic kit Thumbs Up
Generally, you can get away with around 18-20mm of a drop, before ride quality begins to suffer, and still maintain access height, sitting even lower Thumbs Up
Post #422893 Wed Apr 30 2014 6:42pm
Thanks
No, in that picture it is in off road mode. 2012 SDV6 - it's missing a couple of cylinders
Post #422894 Wed Apr 30 2014 6:53pm
micalee
What sort of costs are involved in this (if you know) ?
Post #422896 Wed Apr 30 2014 6:54pm
Disco_Mikey
DIY for as little as £215: http://www.ebay.co.uk/itm/Britpart-EAS-Con...2a2f9da63c
Up to around £450 for a full blown, Bluetooth IID diagnostic tool (dependant on model year)
Expect to pay around £40-£50 for someone else to do it
Post #422905 Wed Apr 30 2014 7:13pm
micalee
Thanks Disco_Mikey for your guidance
Post #422909 Wed Apr 30 2014 7:30pm
You can do it cheaply by buying lowering links. These replace the standard links between the height sensors and the suspension arms. Look on ebay etc. Simple DIY job - the longest part of the job is removing the wheels. 2012 SDV6 - it's missing a couple of cylinders
Post #422922 Wed Apr 30 2014 8:53pm
micalee
Thanks RRSTDV8, that's really interesting reading about these - such an easy mod by the looks of it
Post #422931 Wed Apr 30 2014 9:43pm
If you do decide to run at a non-standard ride height then you should get a 4 wheel alignment done at the new ride height. Changing the ride height changes the suspension geometry and you risk ruining a set of tyres by having incorrect toe settings etc. 2012 SDV6 - it's missing a couple of cylinders
Post #422940 Wed Apr 30 2014 11:35pm
micalee
Brilliant - thanks everyone
Post #422957 Thu May 01 2014 7:27am
LOCUST
Anyone know of someone near Essex that can adjust mine ?
Post #423896 Sun May 11 2014 6:26am
