Home > Technical > Varying ride height |
C11RRJ Member Since: 23 Jun 2013 Location: Northumberland Posts: 17 |
They can be driven in access mode and off road mode below 19mph, anything above that then it goes into standard drive height mode 👍 |
Wed Apr 30 2014 7:23pm |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 |
Presume then the 'high' picture is standard setting then
Wed Apr 30 2014 7:38pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4378 |
They can be driven "low", if the suspension heights have been altered, using the correct diagnostic kit
Wed Apr 30 2014 7:42pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8932 |
No, in that picture it is in off road mode. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Apr 30 2014 7:53pm |
What sort of costs are involved in this (if you know) ? |
Wed Apr 30 2014 7:54pm |
DIY for as little as £215: http://www.ebay.co.uk/itm/Britpart-EAS-Con...2a2f9da63c
Wed Apr 30 2014 8:13pm |
Thanks Disco_Mikey for your guidance |
Wed Apr 30 2014 8:30pm |
You can do it cheaply by buying lowering links. These replace the standard links between the height sensors and the suspension arms. Look on ebay etc. Simple DIY job - the longest part of the job is removing the wheels. 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 30 2014 9:53pm |
Thanks RRSTDV8, that's really interesting reading about these - such an easy mod by the looks of it |
Wed Apr 30 2014 10:43pm |
If you do decide to run at a non-standard ride height then you should get a 4 wheel alignment done at the new ride height. Changing the ride height changes the suspension geometry and you risk ruining a set of tyres by having incorrect toe settings etc. 2012 SDV6 - it's missing a couple of cylinders
Thu May 01 2014 12:35am |
Brilliant - thanks everyone |
Thu May 01 2014 8:27am |
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 |
Anyone know of someone near Essex that can adjust mine ? |
Sun May 11 2014 7:26am |
