Home > Wheels & Tyres > Tyre choice and speedo reading.
Jonipswich
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Hi, my Goodyear 275/40/20s on my RRS 2010 are up for replacement. I have found the ride quality to be disappointing since buying the car 6 months ago. It seems listless at motorway speeds, requiring constant adjustment to keep straight. I read on here that the Hankooks are a good option and that going to 275/45/20 from 275/40/20 can make a big improvement to the ride quality. That post was a couple of years ago. Is the consensus still the same in terms of brand and tyre choice? Does increasing the tyre height from 40 to 45 affect the speedo reading?
Thanks in advance for your help guys.
Jon
Post #420094 Wed Apr 02 2014 2:40pm
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
I recently put 4 x 275/40/20 Hankooks on my RRS 2006, mine stays pretty straight on motorway, I also had the tracking done same time as the wheels. The ride comfort is ok and the road noise is less than more expensive brands. I think I will stick with these. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #420097 Wed Apr 02 2014 3:54pm
Jonipswich
Thanks. Did you stick with the 275/40 or try the 275/45 and if so, did it affect your speedometer? Which Pirellis do you recommend?
Post #420149 Wed Apr 02 2014 10:50pm
It will change the speedo reading because the /45 is nearly 4% larger diameter than the /40. Probably not enough to worry about but you need to remember that your speedo is under-reading slightly so you're going faster than you think. 2012 SDV6 - it's missing a couple of cylinders
Post #420150 Wed Apr 02 2014 11:04pm
drdelrrs
Worth noting that....
Non standard Tyre sizes are a modification as far as your insurer is concerned!
It may affect any warranty you may have if you want to claim for a suspension / drive line issue
In a serious accident a over zealous cop might also point out the Tyre size is not one LR recommend for your car.
Post #420162 Thu Apr 03 2014 7:25am
drdelrrs
Post #420163 Thu Apr 03 2014 7:26am
Jonipswich
Thanks for all your helpful replies. So it seems that 45 isn't the way to go after all and Hankooks get mixed reviews. From what I have read, Pirellis seem to wear out faster than most.
Post #420176 Thu Apr 03 2014 10:21am
