![]() | Home > Wheels & Tyres > Tyre choice and speedo reading. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
I recently put 4 x 275/40/20 Hankooks on my RRS 2006, mine stays pretty straight on motorway, I also had the tracking done same time as the wheels. The ride comfort is ok and the road noise is less than more expensive brands. I think I will stick with these. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Jonipswich Member Since: 30 Mar 2014 Location: Ipswich Posts: 4 ![]() ![]() ![]() |
Thanks. Did you stick with the 275/40 or try the 275/45 and if so, did it affect your speedometer? Which Pirellis do you recommend? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9037 ![]() ![]() ![]() |
It will change the speedo reading because the /45 is nearly 4% larger diameter than the /40. Probably not enough to worry about but you need to remember that your speedo is under-reading slightly so you're going faster than you think. 2012 SDV6 - it's missing a couple of cylinders
Worth noting that....
Thanks for all your helpful replies. So it seems that 45 isn't the way to go after all and Hankooks get mixed reviews. From what I have read, Pirellis seem to wear out faster than most. |
